![]() | Home > Technical (L322) > Noise from power steering when turning right. |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2717 ![]() ![]() ![]() |
Have you checked fluid levels? |
S.Hafsmo Member Since: 02 Oct 2018 Location: Nordland Posts: 170 ![]() ![]() ![]() |
Fluid level i ok. I've also changed the fluid (using correct LR Cold climate fluid). 2007 L322 3.6 TDV8 Stornoway |
None who have experianced such conditions? 2007 L322 3.6 TDV8 Stornoway |
gavinn Member Since: 11 Apr 2017 Location: west midlands Posts: 60 ![]() ![]() |
The noise that you are hearing which is the same as the full lock noise is the spooler valve venting pressure , either your PAS pump needs attention (recon unit) or your rack is on the way out and you have fluid pressure imbalance causing the spool valve to activate.
As long as none of the offending articles are spewing metal debries into the system, thus making short work of other seals, I agree with living with it a while longer.
