Home > Technical (L405) > Tailgat not functioning
Dixy
2016 Range Rover Vogue SDV8 Loire Blue
Pressed the key fob today and it just clicked unlocked. Could open manually but not electronically. Closed it up and left it locked for a couple of hours, tried again still nothing. Phoned the dealer who said bring it in on the 30th, spat the dummy big time and they said if you bring it in now we will have a quick look.
Got down to the dealer and it worked perfectly.
Is there a known problem. letters not necessarily in the right order
Post #521772 15th Jul 2019 11:33am
jumpin mouse
United Kingdom 2015 Range Rover Autobiography SDV8 Aruba
I never know if mine will work from the fob or not but it always works from the switch by my knee or the switch on the tailgate.
Dealer has had it in twice, to no avail.
Post #521785 15th Jul 2019 2:38pm
My lower tailgate won’t close. Opens fine & the upper section is fine - but I’ve just learned to live with manually closing it.
Post #521801 15th Jul 2019 5:32pm
EdJ
In my last L405, the tailgate sometimes didn't open with the key due to - I presumed - low battery. It would often then work as normal when I'd driven somewhere, and the battery had been charged a little. 2024 Range Rover P550e AB
Post #522778 25th Jul 2019 6:02pm
peanutbob
United Kingdom 2018 Range Rover Vogue SE SDV8 Santorini Black
My lower tailgate stopped functioning using the remote. I noticed that, having dogs, there was some dirt/sand in the recesses at the rear of the gate. After sucking it all out with a Henry, it worked again.
Then the manual button jammed later on...so I squirted some WD 40 in and after a few days it resumed operations.
Post #522784 25th Jul 2019 6:59pm
supershuttle
Mine sometimes won't close from the key unless I press the unlock button first (car already unlocked) Geoff
Post #522796 25th Jul 2019 8:43pm
