Home > Off Topic > Looking to buy an air compressor - advice welcome
As per title, am considering the purchase of an electric air compressor with the intention of the following applications:
1. Blow Drying cars after washing
2. Powering Air Tools - e.g. vibrator (to loosen nuts), wheel nut gun etc.
3. Paint Spraying
Would welcome advice on what type/spec might be a good all rounder for the above, and what "best" tools/accessories I may need? .
Post #520995 7th Jul 2019 6:12pm
Weegie
Whatever you get make sure it has a sufficiently large reservoir..IMHO 100 litres is a minimum especially if you are talking about paint spraying . John
GAP iiD BT-Sold
Post #521001 7th Jul 2019 6:35pm
paulbrown22
United Kingdom 2011 Range Rover Supercharged 5.0 SC V8 Stornoway Grey
Agreed, definitely something with a 100l+ air tank, and a decent size motor as well for constant air volume delivery.
Look at the air ratings of the various tools you want to power, and pick a compressor with some spare capacity - I think the ratings are often fairly optimistic in real life usage!
I bought a 50l/2hp (7-8cfm I think) compressor a few years ago for small spraying tasks and other random DIY garage bits, and use it to power inflators, air riveters, spray tools, sanders, etc. It works fine, but even on fairly small tools can run out of air after a bit and the compressor can't keep up with the demanded delivery.
If I was buying again for similar home usage (nothing major), I'd definitely spend the extra ~£150 or so and get something with closer to 15cfm delivery, which I thin is more suited to a wider range of tools.
Post #521007 7th Jul 2019 7:26pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
I've got a 90l belt drive Wolf 3hp which is pretty nice and drives my IR rattle gun easily.
I would stay well away from direct drive as they are noisy, and if noise is a particular concern, get a Hydrovane. They're "less cheap"* and need more regular servicing but they're marvellous.
For air tools, eschew the pcl nonsense and get good quality branded XF fittings add an in-line oiler, and a good regulator. For spraying you should get a decent quality water trap too. beware that overspray can be huge especially compared to HVLP and two pack paint will ideally mean good filtering and a force air respirator.
Like with many decent tools, you spend £500 on a tool and £650 on accessories! Laughing
*a**e clenchingly pricey. Formerly happymadison1978
Post #521121 8th Jul 2019 8:06pm
Pawl
Check the air consumption of any tools you're thinking of buying - usually quoted in cubic feet per minute (cfm) & make sure you're proposed compressor has a higher output. If it hasn't, the reservoir will become very significant as you'll be using air faster than the compressor can supply and will have a finite time before you start losing pressure and output from the tool.
Some tools will not work at all unless there is a certain % of their stated input available, whereas some might work, but at reduced output. Paul,
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Post #521142 8th Jul 2019 11:05pm
m@ttsFF
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
I replaced mine recently with one of these https://www.sgs-engineering.com/sc90b-90-l...ssor-14cfm
I think they’re the same as the Wolf and others with SGs branding , but great value and performance .
Definitely go belt driven .. and look into good airlines that flow well. I have a direct connection straight out the tank for the impact gun and it makes a difference. P525
4.2 SC - sold , now bought back
4.4 AdBlu Tractor - Stolen
Post #522913 26th Jul 2019 9:16pm
Thanks everyone for your suggestions and comments. All looks a bit to "pro" for what I believe I need, but I fully understand what is being said about reservoir size, and the belt drive type compressor.
Will, for starters, probably try something like this, and see how I get on:
(oh no you all groan!)
https://www.sgs-engineering.com/sc6h-6-lit...r-tool-kit
If nothing else, it will tell me what you have already told me Thumbs Up .
Post #522958 27th Jul 2019 10:47am
stanley 24litre one in screwfix for £99 Tim..
edit..£20 for the kit.. ... - .- -.
Post #522962 27th Jul 2019 11:02am
p38arover
Australia
I have a 13cfm compressor - it's not big enough for sand blasting. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #522963 27th Jul 2019 11:11am
