![]() | Home > My Range Rover > My new 2009 Vogue FFRR |
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352
Who looked it over for you?
| jcoops Member Since: 27 Jul 2019 Location: Farnborough Posts: 29
It was looked over by a specialist near where I live. They put it on a ramp and had a 30min look. Not extensive but enough to put me at ease when buying it.
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35874
your FF looks lovely |
Are there any stickies or preferred posts? As you say this is a large forum and searching could take hours!
| nearlee Member Since: 28 Feb 2018 Location: Where the sheep are scared Posts: 252
Nice original example, looks silver rather than grey though. Remember:- amateurs built the ark
| MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 547
DrRob is right on both counts. The jack is borderline and the locking wheel nuts are a nightmare once they swell up.
| ur20v Member Since: 19 Feb 2019 Location: None Posts: 634
Yep, do the egr blanks off eBay. Also do gearbox fluid and filter change. Other than that, normal servicing and care plus any faults that crop up.
What sort of cost are you looking at to change all the oils over? Also just had a look at the LED upgrade and that looks awesome! Will look into that! Thanks |
It's not a big job. Parts-wise should be £150-£200 plus I'd guess a couple of hours labour if you're not doing it yourself. If you opt to do it yourself you need to be able to accurately measure the gearbox temperature when refilling. 2016 Skoda Octavia VRS Estate
On blanking the EGR's there's a hell of alot of information on this forum but it seems like different forum members contradict each other.
Take it to MTS 4x4 in Alton and they'll do all the work for you under one roof in one go including gearbox flush Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Thanks I'll take a look, Alton is not to far.
