Home > Technical (L322) > Heated/Cooled seats control knobs not illuminating |
tj196443 Member Since: 08 Oct 2018 Location: Newcastle Posts: 154 |
Hi
18th Aug 2019 6:40pm |
3528cc Member Since: 29 Oct 2014 Location: North East Posts: 301 |
Update
26th Mar 2020 1:46pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
fyi heated seats work very differently to heated/cool units.
26th Mar 2020 5:04pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34906 |
heated/cooled seats use air where as normal heated only use an element.... ... - .- -.
26th Mar 2020 5:51pm |
Hi everyone, been a while.
6th Feb 2022 5:25pm |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2213 |
It might not help but last year my heated seats stopped working checked everything and no reason for it however I had a sporadic fault with an airbag so I traced every element of the airbag system and checked every wire when finished the airbag fault was still there but the heated seats were working. Interestingly a few weeks later the airbag fault disappeared too so who knows - my guess is an earth |
6th Feb 2022 9:19pm |
Had another session on the RR SC to trace wires, stripped out the glovebox and fuse unit, all appeared ok, tightened a earth cluster in the oh A pillar base, and a couple under the bonnet near the air box. Nothing was corroded
6th Mar 2022 6:49pm |
That sounds very interesting and useful, I’m sure the issue with my rear heated seats are earth related, I also have no vanity mirror lights and the gear selector doesn’t light up red to show what gear is selected. A few months ago I noticed the gear red selector was on and when I checked the rear seats they started to work. When the gear selector light stopped working the rear heated seats stopped working so definitely an earth issue. Someone once said the gear selector red light is wired through the same circuit as the heated rear seats so makes sense. I’ve stripped out the Center consul and checked all the wires and all seems ok. Time permitting I may try your advice and strip out the fuse box and tighten things up, as it happens I do have an annoying tapping / rattle which seems to come from the the bottom of the A pillar on the passenger side so perhaps that’s the smoking gun. |
6th Mar 2022 7:46pm |
DEEBEE(060) Member Since: 18 Jun 2022 Location: Georgia Posts: 35 |
Can you give me an idea of where the earth's are? My heated/cooled are totally dead. Fuses all checked still no sign of life. Any suggestions appreciated |
3rd Aug 2022 12:17am |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1315 |
There's an earth point behind the trim on the passenger side footwell, below the A pillar. This can be accessed by removing the panel above the feet behind the glove box and then gently pulling out. 2015 Range Rover Autobiography 4.4 SDV8 |
3rd Aug 2022 8:48am |
I have a US left hand drive, presume this will be the same? |
3rd Aug 2022 2:55pm |
Land Rover actually go through the expense of moving fuse boxes to the other side so, on LHD vehicles, it will still be in the passenger footwell, just on the right hand side of the car. 2015 Range Rover Autobiography 4.4 SDV8 |
3rd Aug 2022 5:16pm |
Thanks |
3rd Aug 2022 5:57pm |
All cleaned at front end, they weren't too bad but made no difference. Still no lights showing on controls |
3rd Aug 2022 9:16pm |
