Home > Maintenance & Mods (L405) > Sidestep sheared off
United Kingdom 2017 Range Rover SVAutobiography 5.0 SC V8 Aintree Green
Day 1 of the wife's new (19 month old MY67) car isn't going quite so well.
As I parked it up I opened the door at a restaurant I had arrived at to hear a clunk. Odd I thought but couldn't see anything, anyway on then getting out of the car I saw that the sidestep had sheared off at the bracket that holds it onto the mechanical arms.
I've done some searches but can't see this as a noted issue. The car still has the warranty left so assume all will be well, unless the previous owner did something untoward to it of course.
Given it's a LWB I hope it won't take long to get the spare part.
Also I noted in the car the cameras didn't work and it said speak to your dealer they are turned off, odd but I've asked them about that too as I dropped it off with a LR Main Dealer that happened to be about 5 miles away, didn't fancy driving it far with the front of the sidestep flapping around. 1994 Range Rover LSE Autobiography
1994 Range Rover Vogue LSE Softdash
1994 Range Rover Vogue LSE (transmission failed so now a donor car!)
1994 Range Rover Vogue LSE (knackered donor car!)
1993 Range Rover Vogue LSE
1969 Aston Martin DB6 Vantage
1953 Lagonda DB3.0 Drophead Brooklands
1939 Lagonda LG6
Post #524997 15th Aug 2019 9:17pm
In the slim chance they won’t replace it without quibble! I have a spare set of front hinge brackets here is you need them/one sir 👍
Post #525025 16th Aug 2019 7:15am
