Home > Technical (L322) > Error code: p0528-00 (2a) fan speed sensor circuit no signal
Salter121
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Sumatra Black
Hi has anyone come across error code p0528-00 (2a) fan speed sensor circuit no signal - throws the car into restricted performance mode.
Post #525636 21st Aug 2019 8:14am
Jammer600
2009 Range Rover Vogue TDV8 Buckingham Blue
Did you have any luck sorting this?
I’ve got something similar 2018 Suzuki Jimny 2003 written off
2016 Range Rover TDV8 MY10 current
2013 Range Rover TD6 2005
2012 Defender TDCI 2007
2010 Toyota Hilux 2003
2009 Audi TT 1.8T 225
2007 Suzuki SJ 413 with 1600 fitted
2006 Yamaha R6 2000 still have this
2006 Audi A3 1.8T 1999
2006 Defender TD5 1998
2005 Audi A3 1.6 1998
2004 Suzuki vitara 1994
2002 Proton 1500tripple valve 1991
Post #568999 5th Oct 2020 11:10pm
ajtotal
Poland 2011 Range Rover Vogue TDV8 Stornoway Grey
Hi everyone,
Did anyone sort this? I seem to have the same problem.
I pulled two error codes - P0483-37 fan performance + P0528-00 fan speed sensor - no signal. The fan blows at a high speed.
I have read that when there is no signal from the fan speed sensor, the fan starts blowing at its maximum speed to prevent possible overheat. It throws a RED restricted performance and happens only when the engine is hot, needs extra cooling and the ECU probably sends a signal to activate the fan and encounters a problem.
Post #586624 7th Mar 2021 6:40pm
Hojdica
I’ve sorted this by replacing the EGR Temperature Sensor (P040D-00). Aparently this sensor is conected to the fan and cooling system.
Post #605796 6th Sep 2021 10:43pm
RR2B
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Baltic Blue
I have the same error code popping up:
P0528-00 (6 8 ) Fan speed sensor circuit no signal
Triggered on 25-01-2025 13:09:03
At 144179 mi
However, no restricted performance warning - I wouldn't have known there was an issue if I hadn't plugged in my IID.
Noticed the fan is running (at slow speed) even when starting from cold, not sure if this is normal? 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #710710 31st Jan 2025 6:10pm
