![]() | Home > Technical (L322) > Access Height Mode |
Olders Member Since: 17 Mar 2011 Location: Suffolk Posts: 115 ![]() ![]() ![]() |
Hi all.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35836 ![]() ![]() |
access height is used when coming to a standstill so that driver/passengers can disembark comfortably, if this feature wasn't supposed to be used every time then land rover would have made a comment about not using it to much...
The pump often runs during a normal drive cycle, so wear on the pump is not an issue here.
always meaning to ask this question but keep forgetting...do you spray just the outside or all over dan? ... - .- -. Y. O. L. O. . |
Did I miss some sarcasm? (it's been a long day)
no sarcasm dan..thanks |
Many thanks chaps. |
