Home > Technical (L322) > Any way to tell what triggered alarm? 2003 TD6
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
After 10 years of ownership, I had m first ever alarm sound tonight, was a false alarm as no one near it.
Is there any way of determining what triggered it guys?
Or what’s the most likely cause?
It went off at exactly the time I looked out the window at it - strange Shocked
Post #525897 23rd Aug 2019 1:39am
mpirie
Bonnet switch?
Seems to be a common problem.
Mike
Post #525900 23rd Aug 2019 6:50am
steveball
United Kingdom 2010 Range Rover Vogue SE TDV8 Bournville
LR software (Testbook, IDS) lists the last (10, I think) causes of alarm activation. Not sure whether IID tool is capable of doing the same thing. Current: 2010 Range Rover L322
Vogue SE, TDV8 3.6, Bournville
Now gone: 2002 Range Rover L322
Vogue, TD6, Giverney Green
Post #525904 23rd Aug 2019 7:13am
V8Noise
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
Mine threw an oddball alarm a couple of weeks ago. Bonnet switch disconnected and been like a church mouse ever since.
I also put a new battery in as the current one was 2011 vintage and I was also getting the key not turning in ignition.
Everything seems fine now. 2017 5.0 Autobiography Supercharged
2005 Merc SL350
2005 Disco HSE 2.7 oil burner
Post #525906 23rd Aug 2019 7:28am
mrblonde
Cheers guys will check the bonnet switch today...
A thought, mrsblonde didn’t fully close down the parcel shelf yesterday after shopping, middle folding section was in place but the bit closest to you (when at the rear of the car) wasn’t locked into position in the runners, could that of set of off? Maybe I’m clutching at straws.... 🙂
Post #525907 23rd Aug 2019 7:46am
