Home > Maintenance & Mods (L322) > Both rear tyres wearing outer edges down
pk7976
United Kingdom 2007 Range Rover SE TDV8 Buckingham Blue
Have just got in from an hour under the car and given everything a really good levering, with the car jacked up and the rear wheels removed i expected to see some movement in either the bushes or the rose joints on the rear suspension however everything is rock solid.
Do i need to take the weight off them or do anything else to test ?or should i just bite the bullet and send it in for a full wheel alignment?
Post #526586 30th Aug 2019 7:51pm
When were the bushes and rose joints last changed? Was a four wheel alignment done at that time ?
MOT usually testers check with wheels in the air .
Post #526594 30th Aug 2019 9:23pm
horsedentist
United Kingdom 2002 Range Rover Vogue Td6 Giverny Green
I had the same problem anti roll bar bushes were seized solid on the roll bar changed them for the poly bushes and new link arms been fine since.
Post #527507 9th Sep 2019 10:56pm
S.Hafsmo
Norway 2007 Range Rover Vogue TDV8 Orkney Grey
It seems strange to me that the anti-roll bar should have any influence on tire wear, as it does not affect wheel geometry.
Is it outer edges on both sides? You are ofcourse certain the air pressure is correct? 2007 L322 3.6 TDV8 Stornoway
Post #527510 10th Sep 2019 5:08am
horsedentist
Mine was only wearing on one edge (outside) there is no noticeable wear since we did the anti roll bars so I assume it was having an influence on the tyres we didn’t touch anything else on the rear. We did do front and rear roll bars as the links were all worn.
Post #527596 10th Sep 2019 6:57pm
pk7976
Turned out as you all rightly advised to be the rear ball joints, I spent an afternoon under the back end, had it realigned and everything is good
Post #534113 13th Nov 2019 6:08pm
