![]() | Home > Technical (L322) > Fan on |
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 381 ![]() ![]() ![]() |
I would guess it is the FSR that has failed it is a fairly common problem. Mine failed earlier this year it leaves the fan running till battery is flat. I got a BMW one of the internet and replaced it myself with help of YouTube and this forum - it is located behind lower dash panel between steering column and centre console on a right hand drive - quite fiddly to do . 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
madcima Member Since: 25 Oct 2011 Location: Italia Posts: 137 ![]() ![]() ![]() |
I have located the noise, it seems to come from behind the battery, I tried to replace the fsr relay, but without success |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 912 ![]() ![]() ![]() |
It could be the FSR, not the FSR relay.
The FSR I fitted is a Merle 64 11 6 923 204
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3984 ![]() ![]() ![]() |
If the fan noise comes from behind the battery it's possible the fan in the fuel burning heater is coming on due to a fault.
Could it be the ecu cooling fan? 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
Update, I spent the Sunday disassembling the car, doing all the tests, and I realized that the FBH is always on, in fact, besides having downloaded the battery, it drank me a lot of fuel without me turning .....
The FBH is controlled by a printed circuit board located within the casing of the unit itself. These pcb's regularly fail after a number of years. |
I understand .... thanks for the information |
