Home > Maintenance & Mods (L322) > Jacking Up! |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
7th Sep 2019 2:00pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3660 |
With the car in normal height setting the Sprinter jack easily lifts the car to get front or rear wheels off.
7th Sep 2019 2:31pm |
chefkenmore Member Since: 11 Jan 2015 Location: Fearnan perthshire Posts: 685 |
I didn’t realise that there’s a piston inside the piston! So only pumped it to the first stage!!
8th Sep 2019 9:18am |
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 385 |
I had to change a front tyre yesterday after a puncture and had a similar issue! The inner piston appeared to be a bit stuck so it felt as though it had extended as far as it could without lifting the wheel off the ground.
9th Sep 2019 6:49am |
Snowy90 L322 Member Since: 24 Aug 2015 Location: Surrey Posts: 220 |
I personally wouldnt trust a bottle jack on the jacking points just not enough base to be 100% sure it cant rock over, just my humble opinion.
9th Sep 2019 9:23am |
It seemed pretty stable on the Sprinter jack. Not much option when you're out and about anyway.
9th Sep 2019 10:04am |
I suppose the correct term is rear subframe, old habbits! |
9th Sep 2019 10:07am |
