Home > Technical (L322) > Do I remove the map to cure the faults?
Andy
So my restricted performance woes continue.
I took the tin tent to Dorset last week and it faulted 6 times on the way down. Mainly on hills but it did fault twice whilst cruising at 55 on the flat. I pulled onto the services and let it rest at one point and as soon as I pulled into the slip road to rejoin the motorway, it bonged again!
On the way back, I used manual and it didn’t fault for the first 33 miles inc hills out of Dorset through Chideock towards Charmouth. In fact the 33 mile point was just short of getting onto the M5. I managed to reset it at the red traffic Lights before getting on the M5 and I did another 80 miles before it bonged again, on a level section of motorway.
A second reset got me the rest of the way home.
Chatting to someone the suggestion was to remove the map and re- install the factory map. I’m very tempted to do this but what if the map isn’t at fault and I lose the remap? I’m not sure who’s map it is as it was on the car when I bought it and the chap I bought if from said he hadn’t done it.
There is so much inconsistency with this fault. One day it will fly up a hill with no faults , the next it will fault on the same hill.
The strange thing is, when the car goes into restricted mode, it doesn’t really slow down. It’s only noticeable when going up a hill.
It’s gettin to the point where I feel like selling it. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #528825 23rd Sep 2019 9:11am
aljo
United Kingdom 2019 Range Rover Vogue SE 2.0 PHEV Santorini Black
You need to see what the fault codes are showing Thumbs Up Last night I lay in bed looking up at the stars in the sky and I thought to myself, where,s the f**king ceiling!!
Post #528828 23rd Sep 2019 10:03am
i'd check them hoses!!....
also it could be an intermittent fuel pump fault.. ... - .- -.
Post #528829 23rd Sep 2019 10:13am
Andy
I have. I use the IID tool. Same code every time - PO23D map sensor/ turbocharger boost sensor 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #528830 23rd Sep 2019 10:17am
aljo
Have you checked the map sensor to see if it’s clogged up ? And as Stan says check your inter cooler hoses Thumbs Up Last night I lay in bed looking up at the stars in the sky and I thought to myself, where,s the f**king ceiling!!
Post #528831 23rd Sep 2019 10:25am
Andy
Hoses were fine but I replaced them with silicone when I found out about the remap.
MAP sensors have been cleaned and swapped around and the fault still lies on Bank A.
Smoke test was done and nothing was found apart from a hole in the air intake to L/H turbo pipe which I’ve replaced.
Fuel pump is something I haven’t looked at yet 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #528837 23rd Sep 2019 11:56am
cass
Re: Do I remove the map to cure the faults?
"what if the map isn’t at fault and I lose the remap? I’m not sure who’s map it is as it was on the car when I bought it and the chap I bought if from said he hadn’t done it."
Then what have you lost?, you might find that the standard map is better than the remap if you've never driven the car without the map
Post #529183 26th Sep 2019 7:19pm
if its on one bank rather than the other, then it will be something specific to that bank, have a search for the plastic inlet manifold cracks, which are not unknown on the 3.6.
its a while since I saw it but I seem to remember that the rocker cover/inlet manifold can split and cause an intermittent fault. There is nothing that can't be fixed with a hammer😜😜
Post #529185 26th Sep 2019 7:48pm
Andy
I’ve checked the manifolds. I’ve sprayed them with soapy water whilst hot and I’ve also done a smoke test on it.
For the sake of around 40bhp I think it’s worth flashing the ECU. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #529188 26th Sep 2019 8:12pm
Andy
So coming back to removing the map.
I can’t ever recall how a factory standard TDV8 drives. I tested two before buying this one but they were literally a drive around the block not going over 30mph. How are they in terms of power, acceleration and also towing? Will I feel a difference downgrading? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #529702 1st Oct 2019 3:21pm
cass
I doubt anyone can give you an answer to that, there are so many variables, what was the map intended to do? who did it? how well was it done? what other issues could the engine have? etc.
Don't know if it helps or not but i've got a 3.6 and 4.4 TDV8 and while the 4.4 engine (and gearbox) is better in so many ways than the 3.6, I am never disappointed with the 3.6. I tow with the 3.6 and have never wished that I was in the 4.4, the 3.6 never feels lacking and I don't drive slowly.
Post #529706 1st Oct 2019 4:17pm
Fox889
Have you thought about remapping the map?
This way you'd know what you've got, economy or economy/power?
Just a thought? 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
1973 Honda CB250 K4
Post #529722 1st Oct 2019 5:39pm
