![]() | Home > Technical (L322) > How should the car sit? |
umitbat Member Since: 06 Jan 2010 Location: Space Posts: 433 ![]() ![]() ![]() |
Level...
dazza1983 Member Since: 19 Feb 2019 Location: southampton, hampshire Posts: 529 ![]() ![]() ![]() |
weird then,
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1425 ![]() ![]() ![]() |
My experience with older RRs with air suspension has been that they tend to sag a bit at the back, not necessarily to the same extent every time, but in general the longer they sit the lower and the longer it takes for the compressor to get them level again once the engine is started. I just put up with it, sometimes one had to wait a while before driving off, but a system overhaul with replacement of poor seals, perishing bags, worn out compressor etc would be the permanent solution. I'm not sure recalibration would solve it, assuming the vehicle gets level when running. Only Range Rovers since 1988 |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6428 ![]() ![]() |
I always felt my FFRR's looked like they were sagging at the back, even if the suspension heights were correct (vehicle design / optical illusion / etc.)
Thought I’d upload a couple of pics instead might be easier lol.
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1198 ![]() ![]() ![]() |
Our drive isn't level and slopes gently away from the garage. The car, when across the front of the garage, appears to be sitting with less clearance under its "uphill" side. I've assumed the car justs sorts itself out to level if left alone.
Bradders Member Since: 03 Dec 2018 Location: Gods own country Posts: 417 ![]() ![]() ![]() |
Ours driveway has an odd camber to it and our Rangey never looks like it is sitting level on it whereas it does sit 100% level on a flat surface. Now I know, I just ignore it even though several people have commented that the suspension must be shot when they've seen it on the drive. Current: FF Westminster money pit
Hmm bradders and Rich’s post almost contradict each other don’t they lol.
Unnecessary quote removed
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1263 ![]() ![]() ![]() |
Sort of related to this post. Our drive is fairly wide, the section in front of the garage is concrete and has a fair slope on it down to the road.
The things that co fuse me with these cars why would it try and self level when parked up and locked?
Because it can!! |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 570 ![]() ![]() ![]() |
I can relate to your comments, as I often think that mine is sat low at the back although level. Even after it's been sat for a week it looks low, but still level & agree with Joe90's comments.
Dazza
