![]() | Home > Technical (L322) > front prop Q |
| bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 817
can anyone confirm if the front prop on the td6 also fit the 4.4 ??
| RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1042
Yes, the front propshaft is the same, though the final drives are different (i.e. different ratios: petrol = 3.727, diesel = 4.100)
Great stuff , got a bit of play in mine pal so looking for a good 2nd hand one |
Got a replacement front prop , doesnt fit ! Looks like there are 2 types , bolt on or flange |
Theoretically, there shouldn’t be any 5-speed L322s left on the road with the old-style splined pinion drive tube as they should all have been converted to the flexible joint version under Service Action Q041 which was rolled out in June 2008. Your vehicle, like everyone else’s, should have the flexible joint.
That’s amazing that your spline has lasted as long as it has. Generally, a slight misalignment between the propshaft and the final drive unit caused the spline to wear away and eventually fail through fretting corrosion, as huge numbers of us had the pleasure of experiencing.
Blimey phil ! Im glad ive only got a tiny bit of play in it then as i cant warrant the cost of changing the lot |
| steveball Member Since: 09 Jun 2011 Location: Corsham, UK Posts: 208
I would suggest talking to your main dealer. This was a free of charge service action to address a very common failure point. They avoided the term recall for some reason, but to all intents and purposes, that’s what it was. I’m not aware that any time limit was put on the corrective action. You never know your luck - they might do all the work and supply all the parts courtesy of LR. Even lend you a new vehicle for a few days whilst they do it? Current: 2010 Range Rover L322
| Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1885
There was a time limit on the "Service Action" and it expired many years ago
| mercs600 Member Since: 19 Mar 2011 Location: North Yorkshire Posts: 425
Mine failed 7 years ago and the 'recall / warranty' , I was informed , expired the week before. My vehicle was in the main dealers care being driven to the garage when the front prop failed ,and as such they recovered the vehicle at no cost to myself. However it still cost me the thick end of £1000 ! |
