![]() | Home > Technical (L322) > Starting up a diesel |
gettingold Member Since: 03 Apr 2018 Location: Wiltshire Posts: 287 ![]() ![]() |
I get the same if I also don’t use it for a few days. It’s the battery and if I use the car daily I don’t get the message. Nothing really to worry about but awareness these things like to be used and are heavily dependent on battery charge. I wait for the light to go out then turn the key. I also switch everything off until engine start.
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3984 ![]() ![]() ![]() |
The only time I wait for the light to go out is on very cold days in winter otherwise I just start it as you would a petrol engine. Never had any problem, this applies to our other diesel cars as well. |
dazza1983 Member Since: 19 Feb 2019 Location: southampton, hampshire Posts: 529 ![]() ![]() ![]() |
I always turn the key / press the button to position 1 before starting and always have petrol or diesel. I like the idea the car gets a second to sort it’s electrics out before starting.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8776 ![]() ![]() ![]() |
I just get in, put foot on clutch and press the button. I never switch it on then press for start.
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 ![]() ![]() ![]() |
Always wait a few seconds once the ignition is on. Gives time for glow plug to heat up and more importantly allows electric fuel pumps to build fuel pressure 56 TDV8 Vogue SE
Henda Member Since: 02 Aug 2018 Location: Gateshead Posts: 282 ![]() ![]() ![]() |
Always give the system a few seconds to wake up and always let the glow plug light go out before starting . On mine if I don't let the car wake up it throws "u" faults up and needs to be cleared with the iid tool |
