Home > Maintenance & Mods (L405) > Brake Service Mode GAP Does Not work, Workaround?
forever
Hi Folks,
The GAP app cannot put a 2017 RR into service mode to replace the rear brakes, is there a way todo this manually?
Post #529579 30th Sep 2019 2:41pm
Fifth Horseman
From Topix:
ACTIVATION
CAUTION:
This procedure requires the vehicle in the Park or Neutral position, with the ignition turned ON (the engine must be OFF) and the parking brake system released.
NOTE:
This procedure allows the parking brake to be released when removing and installing new rear brake pads or brake discs.
Press and hold the parking brake switch in the release position.
Wait 2 seconds.
Press and hold the accelerator pedal in the wide open throttle position.
Wait 2 seconds.
Turn the ignition Off and back On immediately.
NOTE:
An audible noise will be heard to confirm that the parking brake has been released in Service Mode.
Release the accelerator pedal and release the parking brake switch to the neutral position.
DEACTIVATION
CAUTIONS:
This procedure requires the vehicle in the Park or Neutral position, with the ignition turned ON (the engine must be OFF) and the parking brake system in Service Mode.
Once the rear brake pads or brake discs have been installed, the Service Mode must be cancelled.
Press and hold the parking brake switch in the apply position.
Wait 2 seconds.
Wait 2 seconds.
NOTE:
An audible noise will be heard to confirm that the parking brake has been released from the Service Mode.
Post #529631 30th Sep 2019 10:09pm
forever
Thanks will give that a go...
Post #529656 1st Oct 2019 9:00am
Fleagle_UK
United Kingdom 2014 Range Rover Autobiography SDV8 Luxor
if using the GAP tool, make sure that when you are activating it that the EPB is already in the off position. I made the school boy error of thinking that the GAP tool didn't work when it does - it just requires the handbrake (EPB) to be off - it will then wind the brakes further back..
Post #529688 1st Oct 2019 1:45pm
forever
Yup that's how I did it but gave the E4 error which GAP will look at when they have time!
Post #529692 1st Oct 2019 1:52pm
Fleagle_UK
interesting. I know the e4 error code is just a generic fail.
Are you on the latest software for your GAP tool ? -
Post #529697 1st Oct 2019 2:33pm
forever
Yes they made me update it, so i guess they are able to remotely also see the logs and fail... Maybe it does not work on the later cars and they need to make some software changes?
Post #529701 1st Oct 2019 3:18pm
