![]() | Home > Maintenance & Mods (L322) > IID Tool Tips required |
Hozza12163 Member Since: 10 Sep 2019 Location: Bedford Posts: 51 ![]() ![]() ![]() |
I have changed some simple bits but some others don't seem to work, if you have modded these yourself I would be grateful for a pointer in the right direction if you have a moment?
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2717 ![]() ![]() ![]() |
Cornering lamps are a factory option, not fitted to every car. |
Thanks, how do I tell if I have them? FFRR
found a tip for this which works - sit in the car and wind the mirrors in on the button, get out the car and lock it, unlock it again and they should wind out. This should remedy the issue Mine are now working again! FFRR 2010 TDV8 3.6 Vogue Stornoway Grey |
Looked at an old photo and I think there should be 3 slashes and a visible bulb bellow the indicator, if yours had them , you would definitely notice at night time |
I can't see a bulb in there, is it simply a matter of shoving one in and enabling it in the IID tool, can't imagine there would be separate looms and controllers for each model? FFRR
No idea mate, Craig would be the man to ask. |
