Home > Technical (L322) > How the heck does this remove ?? 2012 TDV8 4.4
Ragingrover
United Kingdom 2014 Range Rover Autobiography SDV8 Nara Bronze
Anyone know how this removes ?? I've turned it anti clock and it pulls up an inch, then thats it, There must be something more to it ? Anyone know ?
Ta :¬)
Post #530175 6th Oct 2019 2:32pm
Baltic Blue
Sorry but I am on holiday at present, 2000 miles away from B.B, or I would post a video showing that it really does just turn 1/4 turn then pull off.
Try turning it a bit as you pull.
It’s just like removing a bayonet fitting bulb.
Mike.
Y G reg 2.5VM Vogue Portofino red 1991- 1999
Post #530178 6th Oct 2019 3:17pm
mpirie
If I remember correctly, you push down against a spring seal, turn about a quarter turn anti-clockwise, then pull up and off.
The bayonet is like a "J".
Mike
Post #530186 6th Oct 2019 4:52pm
aids22
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Rimini Red
Mine would turn but only move up a few mm.
It was just stuck on and required more force that you would expect.
Post #530229 7th Oct 2019 10:43am
Ragingrover
OK and thanks for telling me, so mine's the same. Just needs a good yank ! lol :¬)
Post #530238 7th Oct 2019 12:30pm
