![]() | Home > In Car Electronics (L405) > What happened to spotify? |
| Jase71 Member Since: 13 Apr 2016 Location: Mona Vale Posts: 494
apparently it has been removed from incontrol apps. Only way to access is via apple car play. No idea why they stopped the licence! 2017 Range Rover Vogue V6 Diesel
| brad s1 Member Since: 23 Sep 2008 Location: Boston Posts: 134
Can carplay be put on the old nav where the buttons are arranged physically on either side of the screen vs virtually on the bottom. TIA |
| Mark1107 Member Since: 19 Oct 2014 Location: Los Angeles Posts: 106
| gibbo37 Member Since: 03 Sep 2012 Location: Swindon Posts: 19
Have you seen this?
refers to Australian owners so msybe not here in the UK?. ... - .- -.
I saw a similar article... how do you know if you have InControl Touch Pro vs just in control touch? I have a 2016 which is listed as eligible for the update but says it requires the pro version. Mine has the smaller screen with the physical buttons on either side does that denote just the standard version?
