![]() | Home > Technical (L322) > 3.6 TDV8 running rough |
| LeonL322 Member Since: 06 Oct 2019 Location: London Posts: 4
Ive taken the car to the garage they found cylinder 6 injector maxing out with a offset reading, they removed the injector and found it to be 'wet', so i had them change the injector however the fault still was still present. They then done a electronic compression test and found that a cylinder is only making 1% compression. has anyone had a similar experience with their 3.6??
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35878
the most comon problem on the 3.6 are the turbo hoses..have you checked those ? ... - .- -.
It’s had a new turbo and hoses recently |
| All times are GMT |
