Home > Technical (L322) > New compressor suspension won’t drop |
You mean it will not come down from Off Road height using the dash buttons ?
16th Oct 2019 5:42pm |
S700TNG Member Since: 25 Mar 2019 Location: Tamworth Posts: 6 |
It Won’t go from normal to Access
16th Oct 2019 6:44pm |
Try battery disconnection procedure (to clear ECU and unconfuse EAS ECU)
16th Oct 2019 7:52pm |
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 799 |
I think Joe90 is right , I assume the old comp was goosed ? so its probably got old codes stored up from trying to achieve demands which the old comp couldn't meet ? |
16th Oct 2019 9:56pm |
This is the only think that’s coming up still won’t drop the front
17th Oct 2019 1:31pm |
Did you try the battery disconnection procedure ? .
17th Oct 2019 2:22pm |
Yes |
17th Oct 2019 2:50pm |
Suggest check all your air bags and sensors, then do a calibration .
17th Oct 2019 6:20pm |
Starting to think height sensors are stiff |
17th Oct 2019 7:46pm |
Is there an Exhaust for the front suspension was it just one central exhaust delete all down |
17th Oct 2019 7:47pm |
There is a distribution valve at the front (front RHS wheelarch), at the back (rear RHS wheelarch) and on the reservoir .
17th Oct 2019 10:06pm |
