Home > Maintenance & Mods (L405) > L405 NS side step
Sester
United Kingdom 2014 Range Rover HSE SDV8 Santorini Black
L405 NS side step
Hi all, I’ve had a read through the existing similar posts regarding an issue with deployable side steps. My NS step is stuck out. It goes in but comes back out all the time. So I’ve read to lubricate pivots etc but is there anything else that I need to check ?
Many thanks all in advance !
Post #532110 25th Oct 2019 3:02pm
Small stone dirt ? something bent ?
Sounds like it thinks there's an obstruction when it tries to fold away, so opens back out. I guess just try to observe it from as many angles as possible & see if it catches on anything.
Post #532111 25th Oct 2019 3:05pm
Sester
Thanks. It works as it should just doesn’t stow away. When the rain stops I’ll get under and have a look !
Post #532118 25th Oct 2019 3:51pm
andygts
My drivers side wouldn't come out the day before yesterday after a trip down a few muddy lanes, I jet washed it, then applied some WD40 but to get it to work I had to keep working the step and everytime it tried to move just gave it some gentle assistance. I couldn't see or hear anything catching, it's worked fine for the past 2 days and it's been down more muddy lanes Current
2017 Range Rover Sport SVR
2001 Porsche 911 Turbo
_____________________________________
Previous
2013 Range Rover Autobiography SDV8
2007 Range Rover Vogue SE TDV8
2002 Range Rover HSE TD6
+ Many other non LR products
Post #532126 25th Oct 2019 6:32pm
gentle assistance is a good shout - may help you feel where any resistance is Thumbs Up
Post #532129 25th Oct 2019 7:31pm
nubbin
United Kingdom 2019 Range Rover Vogue SE SDV8 Corris Grey
Get some grease on the pivots as well. WD40 is a water dispersant (WD - geddit? Wink Very Happy ) so some lubricant is now required....
One of mine stopped for a while but was "cured" by a software update although I suspect switching it off and on again would also have worked.
Post #532159 26th Oct 2019 10:33am
andygts
Think you need to read the can.
10 out of 10 for getting what the W and D stands for, bonus point if you know what the 40 means. Current
Previous
Post #532198 26th Oct 2019 4:52pm
40th attempt / 40th formula
Agree with Andy - It's also a lubricant
Quote:
Is WD-40® Multi-Use Product a lubricant?
Yes. While the “W-D” in WD-40 stands for Water Displacement, WD-40 Multi-Use Product is a unique, special blend of lubricants. The product’s formulation also contains anti-corrosion agents and ingredients for penetration, water displacement and soil removal.
https://www.wd40.com/how-to/faqs/
Post #532199 26th Oct 2019 5:03pm
Sester
Thanks all. So today whilst putting some rubbish in the bin, I opened the passenger door and closed it to stow the step. When the step was virtually away, I gave it a gentle “nudge” with my foot 😏 it’s now stowed away. So tomoz I’m going to give them a clean and lubricate in the hope that fixes it !
Post #532235 26th Oct 2019 9:45pm
