Home > Technical (L322) > RSE AV inputs not working - Any ideas?
Wayne Grover
United Kingdom 2006 Range Rover Vogue SE TDV8 Cairns Blue
I've recently bought a 2007 TDV8 with FF RSE - everything appears to work fine other than AV1 & AV2 inputs don't work (both audio & video) - the Aux in jack works fine.
Is anyone aware of a common fault I could look for first?
Confused
Post #57035 28th Mar 2011 12:06am
Wayne Grover
Discovered the front passenger seat had been taken out and dissected the cable when it was put back in!
Works fine with new cable. Thumbs Up
Post #87101 12th Oct 2011 10:18pm
you'll find that and broken cables are the normal causes of 'no rse'.. ... - .- -.
Post #87145 13th Oct 2011 8:43am
