Home > Technical (L322) > Reduced engine performance |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2180 |
there's a bulletin on here which tells you the correct order of the pins i imagine its right.
13th Nov 2019 5:08pm |
Glibbs Member Since: 18 Aug 2019 Location: West Somerset Posts: 100 |
Ah, I did look for a bleed screw on the pump to no avail but do you mean there's one on the hose itself? Range Rover 4.2 SC
13th Nov 2019 5:26pm |
Well I have coolant coming out of the bleed screw above the pump and no air bubbles showing in the coolant header tank. Still I get the message 'Reduced etc'. Ripping my hair out and there's much much of it anyway. . . I must be doing something wrong.
14th Nov 2019 2:13pm |
I don't know the official right answer to this but I know how the Bmw ones work and have followed that philosophy.
14th Nov 2019 3:47pm |
I thank you - nothing is overkill after what I've been through. . .
14th Nov 2019 3:52pm |
fuel pressure - I had it on mine recently when they did the log conversion they hadn't sorted the pressure properly at the time. Ironically it was fixed then the week after it was back but this time it was the pump been good since touch wood.
14th Nov 2019 4:36pm |
Many thanks but I wouldn't a fuel pressure issue trigger an fault that the iid would display? Range Rover 4.2 SC
15th Nov 2019 9:12am |
well you'd think that but I had my fuel pressure hose off for a long time on mine and no fault (its the vacuum hose from the supercharger manifold to the switch with an electrical plug) check that's all on and not fell of?
15th Nov 2019 1:27pm |
I just can't fix it. Been on it all afternoon. No air bubbles. No errors on iid but still "Reduced Engine etc". The engine cover off and I can't see anything untoward.
18th Nov 2019 4:33pm |
you got any faults?
18th Nov 2019 5:26pm |
Hi,
18th Nov 2019 5:29pm |
BTW the error comes up only after running the engine in the drive and then, after about 10mins to warm up, try to rev it and the error comes up after the engine is rough. `Revving to up about 2000 rpm for any length of time does not produce the error. Range Rover 4.2 SC
18th Nov 2019 5:34pm |
Have you0 confirmed wiring is correct way on pump? how long you been getting it? Current stable:
18th Nov 2019 6:27pm |
Also side point but may help have you done your thermostat , and two coolant temp sensors as the coolant sensor can cause looking at the Manual like the maf Current stable:
18th Nov 2019 6:38pm |
