Home > Technical (L322) > Fitting wheels without TPMS Sensors? Bad idea?
M@r]{
United Kingdom 2012 Range Rover Autobiography 4.4 V8 Barolo Black
Hey guys
I'm looking at alternative wheels. The set I have my eye on may not have the sensors. To be honest, I'm not bothered about the functionality, I'm used to regularly checking my pressures anyway. But if I fit them is the car going to throw a hissy fit if it can't contact any sensors? And if so how easy to switch it off?
Post #533795 11th Nov 2019 12:20pm
Iidtool can turn them off. I did it years ago as I was getting too many false alerts. Bloody useless things. Got - 2017 SDV8 Autobiography in Loire Blue
Post #533796 11th Nov 2019 12:31pm
a lack of sensors wont make a difference... ... - .- -.
Post #533799 11th Nov 2019 1:00pm
As above - IID Tool can turn the warning light off - as I understand it's an MOT fail if illuminated.
I hated the TPMS on the L322 - the valves are prone to corrosion. I bought an IID just to turn the warning off after having the TPMS valves removed & replaced with rubber ones.
Post #533803 11th Nov 2019 1:30pm
Strider
First thing I did when I got my IID Tool was turn the b**** thing off.
From Gov MOT website :-
Vehicles first used on or after 1 January 2012 will be checked to make sure the tyre pressure monitoring system (TPMS) MIL is working.
Post #533805 11th Nov 2019 2:14pm
Sandyt
+1 bloody useless things
But as said it is an mot failure if showing a fault but if switched off no problem
Bit like bald spare wheel
Post #533810 11th Nov 2019 4:21pm
