![]() | Home > Technical (L322) > Heated steering wheel problem !! |
simonmanx Member Since: 17 Feb 2010 Location: Isle of Man Ballasalla Posts: 157 ![]() ![]() ![]() |
I know its getting warmer unlike this morning but does anyone have an idea what could be wrong with my heated steering wheel !! when i press the button the red light now only comes on for a split second then goes out and obviously the steering wheel does not heat up !! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35834 ![]() ![]() |
found this via the search, seems you need to strip and inspect
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 ![]() ![]() ![]() |
i can almost 100% say that it will be the actual heating element in the wheel that is faulty, i had the exact same problem and the only way to fix it was to replace the steering wheel with a new one, soon as i did that the heating function worked straight away.
Jsb Member Since: 24 Nov 2010 Location: Southampton Posts: 78 ![]() ![]() ![]() |
I have a working wheel, removed from my 2007. Let me know if you are interested in it. |
bogie Member Since: 06 Nov 2010 Location: Notts/Sth Yorks/Lincs border Posts: 208 ![]() ![]() ![]() |
same here - thats how I fixed mine - on exchange £100 ish from powerfulUK cheers bogie |
