Home > Maintenance & Mods (L322) > Removing the AUX inputs panel (back of the center console)
michu
United Kingdom 2005 Range Rover Autobiography 4.2 SC V8 Oslo Blue
Hi all, first post as I'm on my first month of my first RR Smile
I have the 2005 Autobiography with RSE. The 3.5mm AUX input accessible from the rear seats under a small retracting cover came with a broken plug stuck inside. I wasn't able to pull it out while mounted in the car, so I think I need to remove the whole panel for surgery at home. Any tips on how to do it? I could only find videos about removing the upper panel right where the cubby hinge is, but nothing on the bottom part; hopefully there's a way to do it without dismantling the whole center console?
Post #533880 12th Nov 2019 9:46am
anything in the WM? ... - .- -.
Post #533903 12th Nov 2019 12:11pm
michu
Frankly, I don't know where to find one. Complete newbie to RR here!
Post #533904 12th Nov 2019 12:14pm
top right of the page is a 'wiki' link, click on that and in the wiki near the bottom is a WM link download....you can also use the forum search function... ... - .- -.
Post #533905 12th Nov 2019 12:22pm
Baltic Blue
It’s in the Wiki .
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #533907 12th Nov 2019 12:33pm
michu
Found it! Thank you for the pointers.
Actually it's a bit different in a 2005 model. There are two screws at the bottom of the rear console cover that I didn't notice yesterday when looking at this with just a flashlight after dark.
Post #533909 12th Nov 2019 12:48pm
MattHughes86
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
push both front seats all the way forward, makes life alot easier.
had to have mine apart to clean up the drink my son spilt in it.
Matt If In Doubt Give It A Clout
Previous Vehicles:
Land Rover 110 3.5 V8 (is my dads though)
1.9TD Seat Toledo
1.4 Rover 214 (dont ask)
2.0 Nissan Primera SLX (i want it back)
1.4 Seat Ibiza
996cc Toyota Aygo (I miss this car???)
04 TD5 Discovery 2 (my Current Car)
07 4.2 SC FF (wifes car)
Post #533915 12th Nov 2019 2:05pm
michu
Already done.
The "two screws" haven't been screws at all, but plastic fasteners. Apart from that, some careful wiggling of the panel allowed to remove it.
Next, two electrical connectors needed to be removed and I took the whole panel home.
The connector module was mounted using three Torx screw, then there was internal electrical module - another three Torx screws. After removing it and unscrewing another two Torx screws (all different sizes for some reason) holding internal circuit boards, and prying some small plastic latches, the boards could be finally removed.
I thought I'll need to unsolder the 3.5mm socket because it was a closed kind with no access to remove the plug from the side, but I managed to pull the part of the plug by drilling it with a small PCB bit and pulling on the bit, and then the remaining fragment came out after squeezing and leveraging with some precision metal shears of this type: https://www.modellingtools.co.uk/xuron-pro...0948-p.asp (tweezers didn't have enough hold).
Post #533921 12th Nov 2019 2:46pm
MattHughes86
im now jealous your SC was a quick fix...
mine not so much the heads are currently sat on the work bench....
Previous Vehicles:
1.9TD Seat Toledo
1.4 Seat Ibiza
Post #533944 12th Nov 2019 5:55pm
