Home > Technical (L322) > No Parking/hand brake on warning light (Newbie first R/R)
On The Edge
Wales 2005 Range Rover Autobiography Td6 Mariana Black
Hi Newbie first R/R so I no nothing about them
There isn't any dash board hand brake on warning light ?
Your Help & advice please.
Thanks.
Post #533969 12th Nov 2019 8:28pm
Clivefog
Does it light up on the initial self test before starting the engine?
Post #534056 13th Nov 2019 12:32pm
cant remember what mine did but i think its only the electronic handbrakes that have the 'P' icon lit up when the park brake is on... ... - .- -.
Post #534058 13th Nov 2019 12:38pm
On The Edge
Yes it does light up on the self test for a couple of seconds but not when the handbrake is pulled up.
Post #534083 13th Nov 2019 3:47pm
On The Edge
Owners Handbook = Should light up when Handbrake applied or if there is a fault with the Handbrake
system.
Post #534084 13th Nov 2019 3:58pm
Clivefog
Bulb is fine must be the hand brake switch end. On the passenger side of the lever is the switch hope it is this as there is no doubt several miles of wiring/connections/strange black boxes etc.. Check the switch as a first step.
Post #534088 13th Nov 2019 4:17pm
On The Edge
Thanks will remove console cover and gear Knob to see what I can find.
Any idea what switch looks like and exactly where is it located?
Sorry but this is all new to me Embarassed
Post #534107 13th Nov 2019 5:34pm
theres a WM link in the wiki that might help.. ... - .- -.
Post #534108 13th Nov 2019 5:35pm
On The Edge
Thanks but whats a WM Linc ?
Post #534112 13th Nov 2019 6:04pm
Clivefog
Click on the WIKI link at the top of the page scroll down to brakes then handbrake WM = Workshop Manual
I think the link on Stan's post also works
Post #534114 13th Nov 2019 6:10pm
On The Edge
HI think I got it now - Workshop Manual
Thanks
Post #534115 13th Nov 2019 6:11pm
On The Edge
Finally had the time to take a look at Handbrake light switch - wire had broken off the copper connecter holder thingy managed to fix with a bit of improvisation and it now works again Very Happy .
Thanks for the help & guidance Thumbs Up
Post #535453 25th Nov 2019 10:42pm
DrRob
Thumbs Up Bow down Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #535454 25th Nov 2019 10:47pm
