![]() | Home > Technical (L322) > Alternator output on td6 please ? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35841 ![]() ![]() |
your year WM says 14.5v... ... - .- -.
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3984 ![]() ![]() ![]() |
The alternator output varies according to the charge level of the battery and the equipment running on the car.
Johnsd1v8 Member Since: 06 Jul 2017 Location: Cheshire Posts: 190 ![]() ![]() ![]() |
Thanks guys i thought it was too low that not enough to charge a battery of that size where abouts are the engine to body earth lead (s) on the td6 i will try the jump lead trick though that worked on one of my old cars few years ago |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 807 ![]() ![]() ![]() |
I have been having battery issues recently and can confirm that at normal tickover the alternator output is 14.1v / 14.2v .
What was causing your drain issue mate |
Sorry I must have not been clear, Car tested fine but for reference Alternator pumping out 14.1, 14.22v. Drain test after sitting for 30 mins 35mah. New battery and all is well
Could it be possible that my new battery has failed or failing all ready |
it does sound like the alternator is not putting out the correct voltage...i'd have it checked out.. ... - .- -.
Am i right in saying there is 2 types of alternator for it one that has 3 pins and one has 2 pins on the black plug connector |
Thanks all for the help ive done my td6 today found the engine earth on the aircon pump all with molten metal from the bolt around it so took that off cleaned up new bolts and a fitted a extra earth from the strut top to the back of power steering pump fired car up and now charging at 14.2 and with lights and blower on full blast it charges at 13.9 to 14.0 volts hopefully all is well now |
thanks for the update on the fix, always good to hear the outcome 2007 TDV8 VSE
