Home > Maintenance & Mods (L322) > Lots of condensation on inside of windscreen every morning
Danwilderspin
Ok with all this cold weather we have noticed a lot of condensation every morning on the inside of the 4.2 the 4.4 did not seem to get this. There is a lot a micro fibre cloth will be sopping wet.
Any ideas of the cause here? It had a leak which I thought I fixed with the drains but maybe not? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #535902 29th Nov 2019 11:39pm
Sounds like you have a leak - at least water somewhere
Do you continue to tun aircon through the winter ? that can help dry the air.
I have a Mini that does something similar, but can't figure out where the leak might as there is relatively little moisture and no wet carpet that I can find, so I just put one of these in there through the winter
https://www.ebay.co.uk/itm/151-Interior-De...SwKJtaqmF1
Post #535920 30th Nov 2019 8:23am
Definitely have water in it Dan, classic symptoms... Neutral
Post #535924 30th Nov 2019 9:32am
John w
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Just sold my mother's car, which had exactly the same. Her car definitely had a leak though.
She was using the things Alistair has linked to, that kept it under control. Too many toys, not enough time
2011 4.4 TDV8 AB Black
Post #535962 30th Nov 2019 2:28pm
Mulcher
England 2006 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
My 4.2 SC does that too. One time I noticed it in the evening so I got in to mop up and noticed how very warm it was inside the car. I left both front doors open for 10 mins till the inside and outside air temperatures equalised and the condensation disappeared and the windscreen was still clear the next morning.
My guess was that these vehicles must be very well sealed and retain the heat and humidity after driving such that the condensation is caused by the temperature differential. 2006MY 4.2 SC
BMW R1250 GSA Rallye TE
Triumph Tiger 1050 (sold)
1979 Pontiac Trans Am (sold)
Post #535979 30th Nov 2019 4:37pm
Danwilderspin
What’s the best way to do some leak investigation?
I was thinking wait for a nice dry day and drop the headlining 10-15cm and get the pressure washer out give it a hard going over and then see where it’s coming in? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #536028 30th Nov 2019 10:29pm
DrRob
You got a sun roof? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #536030 30th Nov 2019 10:41pm
Do you run with the air con on
Do you run on recirculate? Moisture has got to go somewhere.
Check the usual suspects, sunroof drains rear compartment etc
Also where is the air con dryer on these, I remember on our hilux the drain had got blocked which caused the dryer to fill the cabin with water..... There is nothing that can't be fixed with a hammer😜😜
Post #536033 30th Nov 2019 10:48pm
Fox889
A smoke bomb (serious) will find any gaps & show with errrr smoke!
Saw it done on an old Wheeler Dealers show.
Now where you get them I know not.
Hope this helps. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
1973 Honda CB250 K4
Post #536035 30th Nov 2019 10:54pm
RichM63
France 2006 Range Rover Vogue TDV8 Stornoway Grey
Keep the pressure washer away from the sunroof. If it didn't leak before the test, it will afterwards!
With all the recent heavy rain, we people introduce lots of moisture, from stuff like 'breathing', damp clothing, wet shoes etc.
If you have to carry live wet people use the roof rails, keep a window cracked open half an inch when driving, and on a sunny winter day seize the chance to park in the sun with all the windows and tailgate open for a couple of hours.
Remember to close up not much later than 3pm as the temp/humidity, drop/rise again.
Best
Post #536047 1st Dec 2019 9:45am
Danwilderspin
Hi All
I have a sunroof and it had 3 of 4 drains blocked in the summer. I found this out as I had a dead break unit with water all over it.
I cleaned all those new Bluetooth etc and today checked rear compartment no puddles or anything but the metal exterior of all units (dvd changed, amp etc) all had serious condensation on?
Any ideas?
Rich - I definitely think there is an issue my 2002 didn’t do this ever ... Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #536213 3rd Dec 2019 12:26am
supershuttle
Don't jump to the conclusion that there must be a leak. All three of my cars (SWMBO's one is actually new) have all suffered from significant condensation (water running down the inside of the windscreen) during the recent cold snap. However, they all recovered just fine after the initial condensation was removed (good old fashioned chamois) and as it has got warmer the problem has not reoccured. I'm not suggesting that it is not a leak, it may well be, but dry it out and see if it happens again.
Another thing to ponder on in leak analysis is, has it actually been raining where you are, here it hasn't, not rained for days in fact - too cold.
So in those immortal words "Don't panic Mr Mainwaring" - well not just yet at least. Very Happy Geoff
Post #536220 3rd Dec 2019 8:20am
Danwilderspin
That’s a fair point.
I have decided not to do anything too invasive and will follow up on fox889 idea first.
Have ordered these should be here for the weekend.
REGIN REGS25 KS10 Pellets x 10 https://www.amazon.co.uk/dp/B00O12WAVU/ref...5DbZYG8X4G
Paranoid about flames in the car so going to put in an old chime bowl and then put that in a bigger bowl full of water.
I’ll shut all the vents If nothing comes out next stop is dropping the headlining but I will wait for it to warm up to confirm there is definitely a leak first Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #536230 3rd Dec 2019 10:14am
Big Boy R44ROV
I had similar when I had the windscreen replaced a few years back on my old 4.2. It hadn't been fully sealed and allowed moisture to get in.
Only found out months later when it got cold ! Tony
You're always in the Censored ........it's just the depth that varies
2014 L494 5.0 S/C AB Silver
2014 L494 3.0 HSE in Chilli
2014 SL63 AMG White
Gone:
2011 5.0 L322 White (Stolen)
07 4.2 SC in silver.
06 4.2 SC in black RSE
RRS 4.2 SC in Black RSE
52 4.4 Vogue in silver
04 Mercedes CLK 320 Conv
03 4.0 V8 ES Disco in Silver
00 TD5 90 County
98 4.6 HSE in Epsom x3
97 3.9ES Disco
93 L 4.2 LSE in black
too many classics to mention !
Post #536246 3rd Dec 2019 12:16pm
Danwilderspin
I had a new windscreen but also had sunroof leak so hopefully a smoke test will rule in or out some of this... Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #536278 3rd Dec 2019 3:38pm
