Home > Technical (L322) > Sorry !! AGM or No AGM ?
Ragingrover
United Kingdom 2014 Range Rover Autobiography SDV8 Nara Bronze
My 2012 4.4TDV8 has the origonal LR battery and although it starts just fine I'm getting problems with the FBH and radio won't stay on for more than 5 minutes. So maybe its due a change.
So sorry to ask this old chesnut again but is AGM really required ?? Double the price means its worth asking first.
K
Post #536152 2nd Dec 2019 4:04pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
I doubt all of your issues are to do with the battery !
But it *should* be AGM Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #536153 2nd Dec 2019 4:10pm
Ragingrover
I've read so much about problems relating to even slightly low battery voltage, including the FBH. I like the easy fixes first :¬) .. where possible of course !
Post #536155 2nd Dec 2019 4:14pm
yes , yours should be an AGM... ... - .- -.
Post #536156 2nd Dec 2019 4:18pm
Ragingrover
Great thanks, AGM it is then
Post #536159 2nd Dec 2019 4:21pm
Bushy30
Battery might fix the FBH, doubt it's the radio issue though Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #536161 2nd Dec 2019 4:31pm
M@r]{
United Kingdom 2012 Range Rover Autobiography 4.4 V8 Barolo Black
Should all the batteries in the L322 be AGM then? I don't think mine is?!
Post #536168 2nd Dec 2019 5:42pm
Baltic Blue
All 2010-12 4.4 tdv8’s should be AGM. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #536169 2nd Dec 2019 5:58pm
Andy
I just bought an Exide AGM for £125 from euro car parts. Fitted it yesterday 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #536177 2nd Dec 2019 7:07pm
kooky_guy
United Kingdom 2010 Range Rover Vogue SE TDV8 Stornoway Grey
If you mean the radio won't stay on for more than 5 minutes with the engine off, then yes I'd say your symptoms point to a dying battery.
Mine started fine but the FBH wouldn't fire up. The rest voltage was quite low at 11.4V or something similar - be worth checking that first, maybe.
New AGM battery fixed the FBH! 2010 4.4 TDV8 Vogue SE
Post #536221 3rd Dec 2019 8:45am
