![]() | Home > Technical (L322) > 2011 4.4 TDV8 Cranks but won't fire after battery change |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35841 ![]() ![]() |
you shouldnt have any problems by simply changing the battery..i suspect theres a loose wire somewhere that you may have missed..
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3880 ![]() ![]() ![]() |
I would start by looking at the bonnet lid switch., but it is a wild guess.
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1198 ![]() ![]() ![]() |
+1 with Mike AND Stan^^
rw90 Member Since: 07 Mar 2019 Location: Scotland Posts: 35 ![]() ![]() ![]() |
Thanks for the rapid replies!
Laurie915 Member Since: 11 Sep 2011 Location: Canberra Posts: 72 ![]() ![]() ![]() |
Try your spare key ! Have had a bad key-fob battery do this. If no good; lock car wait 3 mins and try again, the immobiliser might need re-setting.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2752 ![]() ![]() |
Maybe add some fuel in case the gauge is lying. |
Update: Having run out of daylight, I left the car for 48hrs and guess what... ...it started 1st time, but also now says restricted performance. Very odd electrical gremlins! |
