Home > Technical (L322) > 2007 4.2 Sc alternator denso part
dingg1
Number required if anyone knows it, I'm on a mobile phone and have no computer access for a while to Google properly.
Any help would be appreciated
Very Happy
Post #536483 5th Dec 2019 6:16pm
nino_nino
YLE500390 DAN991 DENSO (NEW) ALTERNATOR 4.2 & 4.4 05-09 YLE500190
https://www.advancedfactors.co.uk/yle50039...3413-p.asp 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #536545 6th Dec 2019 12:07pm
kezbo1981
United Kingdom 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
What he said.
I'm selling a used one if you are inyerested: https://www.fullfatrr.com/forum/topic52025.html
Post #536794 9th Dec 2019 4:38pm
dingg1
Thanks for update guys
I'd like to fit new as I don't want to have to do it again for a while.
Mine is limping along putting out 13.7v
But had a squeeling moment when it was down to 13.5v and the battery light was on.
Threw a load of wd40 and silicone into it and it's been OK since.
Will buy it one for Christmas
Post #536797 9th Dec 2019 5:10pm
dingg1
Threw a load of wd40 and silicone lube into it and it's been OK since.
Post #536798 9th Dec 2019 5:11pm
andyt109
How hard was this to change please? Did you get it done by a garage? or if you did it yourself did you do it from below or above?
Thanks
Post #577098 24th Dec 2020 2:36am
dingg1
Garage did it for me, as I had the water pump done at same time and didn't want to do that one as it looked too much lying on my back.
Water pump can be manipulated out after removal of the headlamp and coolant header tank though to give you some room.
Good luck 🎅
Post #577101 24th Dec 2020 10:10am
dingg1
Think you need to access from below 🙄
Post #577102 24th Dec 2020 10:11am
dingg1
Should have said alternator can be manipulated out, its early Embarassed
Post #577103 24th Dec 2020 10:26am
Piet
Netherlands 2008 Range Rover Autobiography 4.2 SC V8 Lucerne Green
Hi Sirs,
I did that job two weeks ago.
On my car, rhd I know I know, there was no space to get the
alternator out from underneath. So I just loosen it from below.
Than I took the main cooling fan, shroud and expansion bottle
out. Mine bottle is on the left hand side. That gives me the
space to lift the alternator out.
Job it not difficult but there is not much space to loosen the
+ cable and the connection plug. Thats a little bid fiddling.
Remember ....... lose is in the normal running direction
of the fan. Always. Spanner is 36mm.
Post #577126 24th Dec 2020 7:45pm
