Home > Technical (L322) > L322 suspension fault - towbar module?
JonnyO
United Kingdom 2004 Range Rover Vogue 4.4 V8 Stornoway Grey
My L322 has a suspension inactive fault. I have lights on the control but it will not go up and down, but just sits at the 'normal' height.
When it was in the garage recently for something else, I asked them to diagnose what the fault was. Unfortunately, my wife collected the car so the answer was a bit garbled by the time it got to me. I think they said it was due to a towbar module in the boot area. Does this sound correct? If so, does anyone know how I can get to it and swap it out?
Post #537203 12th Dec 2019 4:20pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Module is in the boot, rear right cubby as you look forward into the car, open the cubby and look towards the rear of the space, you should see a grey module tucked up in the corner -- disconnect it and see if it cures the issue, disconnection should have no other effect (other than disconnecting the towbar electrics) Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #537205 12th Dec 2019 5:35pm
JonnyO
Can’t see the module. Any further help as to how I find the damn thing?
Post #539017 31st Dec 2019 4:03pm
What tow bar do you have, is it OE or aftermarket?
If you lift the boot floor and trace the towing electric wires back from the grommet the you should find the towing module, first box you come to Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #539018 31st Dec 2019 4:17pm
Bushy30
Take a photo of the rear right cubby and post it Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #539042 31st Dec 2019 7:18pm
JonnyO
Never did get to the bottom of this as it was an aftermarket tower with a rats nest of cabling Sad. Anyway, the car has been sold now
Post #564851 17th Aug 2020 9:43pm
