Home > Technical (L322) > Which suspension have I got?
TDV8_Tommy
Spain 2012 Range Rover Westminster TDV8 Baltic Blue
Replaced the rear pads on the car today and noticed the passenger side rear shock was coated in oil, so will need replacing.
When looking at rear shocks some as listed as ‘Continuous Variable Damping’ vs normal ones - not sure what to go for.
What is the standard set up for a late 2012 TDV8? Are Bilstein‘s factory-fit?
Thanks 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
1997 P38 2.5 DSE auto & 1998 P38 2.5 DT Manual
1988 Vogue 3.5 EFI - Manual, gone.
2004 Volvo C70 2.0T convertible, had since new.
2007 Mazda MX-5 2.0 Sport Roadster/Coupé, had since new.
2024 Mini Cooper S cabrio, JCW kit, 2.0, DCT auto
Post #537402 14th Dec 2019 5:30pm
nino_nino
You have Continuous Variable Damping, for the rear shock - they are known to "sweat" a bit but are OK. so if oil is not dripping You are ok 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #537423 14th Dec 2019 7:11pm
GraemeS
Australia
I fitted Bilsteins - cheaper than LR but no adverse effects.
Post #537427 14th Dec 2019 8:08pm
TDV8_Tommy
Thanks, chaps.
The ‘wet’ one in question is Bilstein.
If anything I’d like a softer ride, has always felt quiet firm. 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
Post #537432 14th Dec 2019 8:28pm
mpirie
The hard ride may be more down to the (lack of) sidewall in the tyre?
I've read reports that moving to a 19 inch wheel and tyre setup can improve the ride.
Mike
Post #537433 14th Dec 2019 8:39pm
Baltic Blue
Or next time you fit new tyres consider 255 55 20.
The ride difference is very noticeable softer compared to 255 50 20.
Post #537434 14th Dec 2019 8:46pm
TDV8_Tommy
Can you go to “19s on Brembo braked FFRRs? 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
Post #537442 14th Dec 2019 9:51pm
rjff
Got these on mine 19" running255/55/19
These are the original style, don.t recall the number but it's on here somewhere. I believe there are others that will fit. Again on here. Cheers
Richard
Gap IIDBT
Post #537449 14th Dec 2019 11:53pm
GraemeS
Australia
D4 19" fit - I've had a set on mine and most likely will go back to 19" when the current 275/55R20 need replacing as I find them too big and nothing much here in 255/55R20.
Post #537458 15th Dec 2019 1:23am
mpirie
Yes, but only on that one style of wheel I believe.
Other 19's will foul the calipers.
Mike
Post #537480 15th Dec 2019 10:34am
