Home > Maintenance & Mods (L322) > CV JOINT Rubber Housing
bruno22rf
England 2004 Range Rover Vogue 4.4 V8 Java Black
04 4.4 petrol - just enquired about replacing my front CV Gaiter and have been informed that my garage don't bother replacing them anymore as it's just as quick to replace the entire drive shaft - obviously the cost is much higher - does that sound right?
Post #537654 16th Dec 2019 5:02pm
rjff
If the gaiter has failed, say tears, splits or holes, then whatever it's protecting has been open to the elements. That means extra wear and tear. I would probably replace the whole shaft, but would only make the assessment on my own car.
If, in your opinion, the garage make a sensible case, then replace the whole thing. Cheers
Richard
Gap IIDBT
Post #537657 16th Dec 2019 5:26pm
Rambles
I just replaced the offside CV gaiter on my MY11.
It was split and leaking grease, but still had plenty of grease packed around the joint.
So just a replacement of the boot.
Post #538638 27th Dec 2019 8:47pm
JST
England 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
mine had a small hole in and was leaking grease. cleaned it and super glued it up 2years ago. Cheers
James
Post #538661 27th Dec 2019 11:35pm
