Home > Maintenance & Mods (L322) > Rated recovery points for 2004 RR L322 |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 775 |
I am pretty sure the tow point in the centre of the car is heavily rated and good enough for a snatch. Use a receiver tongue in the rear . Always use a damper you dont want to kill yourself or others
24th Dec 2019 3:36am |
RSW vogue 2004 Member Since: 30 Nov 2019 Location: New South Wales Posts: 11 |
According to my user manual both on and off road flat tow points only. No mention of being able to handle snatch type pressure |
24th Dec 2019 3:48am |
Only hearsay however I used to do lots of hardcore offroading with the AULRO group and there were some very knowledgeable guys there. Some trips demanded rated recovery points for admission, P38a`s not allowed, L322s OK. I would not use the rear tow eye only as a recovery hitch is so easy to attach and is central. Have you had a look at the front tow eye, its no tie-down point. 2007 TDV8 VSE
24th Dec 2019 4:06am |
The book states flat tow only for front ring |
24th Dec 2019 4:13am |
My handbook states rear eye can be used in off-road recovery situations, front eye cant be used to tow caravans or trailers. I have both snatched and been snatched and winched from the front eye with no dramas but always take care and nothing to violent. Your call I think, I have seen nothing aftermarket sold or fitted only D3 bullbars that will never have compliance approval. Hard Range was tricking up a TD6 long ago, see if you can find any info from them, if anyone has done it, they would. 2007 TDV8 VSE
24th Dec 2019 5:54am |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1341 |
The eye at the middle front seems fine, I've been pulled out when 'bellied' in the mud in my 2004 car using that. I recall the handbook warning about being pulled out from the rear as regards possible gearbox damage, you might want to check that before doing that. As I have a towbar I would attach to that at the rear, so have not needed to try anything else. Only Range Rovers since 1988 |
24th Dec 2019 2:29pm |
G'day All,
29th Dec 2019 10:25am |
Have a look at Harry's Garage on You Tube, his review of the L322 for daily use. In the clip he mentions something about the design rating of the tow points and their snatch load. He is a special adviser to JLR and the editor of Evo magazine, so I think he has some pretty good info (although I did have to correct him on something, have a look at the comments ). MY 2010 5.0 SC Galway green and sand interior!!
29th Dec 2019 11:31am |
Thanks very much for that youtube video. According to Harry's Garage the front hook is rated at 7 tonne, so well enough for snatching and being snatched.
30th Dec 2019 2:28am |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
I also remember Clarkson talking about the rear driver's side hook being several tonnes worth....
30th Dec 2019 9:31am |
Thanks GGDR for that information but I have the back covered with the hitch block with D shackle. Just the front was my target.
30th Dec 2019 9:40am |
