![]() | Home > Technical (L322) > Brake squeak when reversing |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35841 ![]() ![]() |
could be a bit of grit/stone between the backplate and disc... ... - .- -.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3880 ![]() ![]() ![]() |
One of the retaining springs broke on my td6 Park brake and I only heard that when reversing, but I am not sure if it is different on the 2011., but definitely worth getting someone to listen while you reverse, at least to determine which side is squeaking.
scuddriver Member Since: 12 Feb 2015 Location: Dunbar Posts: 140 ![]() ![]() ![]() |
But I guess I would hear a squeak going forward as well as back? 2011 Vogue TDV8 4.4 1992 Mazda Mx5 |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 787 ![]() ![]() |
Not necessarily- my 2011 only made a noise in reverse when the pin snapped |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8776 ![]() ![]() ![]() |
Strip and clean the calipers
