Home > Technical (L322) > 4.4 TDV8 oil leak
madpugger
4.4 TDV8 oil leak
Hi all
I’ve got a 4.4 TDV8 which just deposited a whole load of oil along the road and in the drive! It’s not empty so hopefully not too much damage...
It’s hard to tell where it’s coming from, but is N/S. I’m assuming somewhere near the turbo.
So two questions.
1. Can the turbos be changed with engine in on the 4.4? Or perhaps a better question, what’s involved?
B. How the hell do you get it in neutral without starting the engine, for example to tow it? The manual says refer to service technicians manual!
TIA[/quote]
Post #538591 27th Dec 2019 3:18pm
CS
To select neutral remove the insert from the front cup holder unit and find a slotted head screw beneath, turn that and it should go into neutral. Note that RRs should not be towed any distance, they need to be carried on a truck or trailer, otherwise the transmission will be damaged. See more detail in handbook. Maybe also via search on here, I recall another thread not so long ago. Only Range Rovers since 1988
Post #538592 27th Dec 2019 3:30pm
madpugger
Perfect thanks.
When I say tow I meant to winch on to trailer and then onto 4 poster... Smile
Thanks!
Post #538595 27th Dec 2019 4:05pm
mjdronfield
https://www.fullfatrr.com/forum/topic54000.html
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #538602 27th Dec 2019 4:55pm
madpugger
Thanks. I got neutral no problem. It’s the turbo oil pipe I’m now trying to access...
Post #538604 27th Dec 2019 5:11pm
Check where the oil is coming from. If I’m not mistaken the other end of the oil feed pipe comes from the back of the engine and if it is coming from the top end of the pipe then it is an easy pipe to access and is fixed with 2 new Orings have a search there is loads on here about the fix and how to do the Orings. There is nothing that can't be fixed with a hammer😜😜
Post #538609 27th Dec 2019 6:11pm
madpugger
Thanks,
It appears to be lower half to N/S turbo, possibly from the drain. It’s hard to tell.
Regardless, I don’t think the oil supply o ring can be “easy” to change, at least on the LHS turbo? I can’t even see the turbo end of it!
From where we’ve got so far, I’d say it needs driveshaft out, engine mount off. Subframe off and diff off to even entertain getting to turbo pipes?
If anyone has actually swapped a 4.4 turbo I’d be keen to know how far you stripped things back to do it!
Post #538624 27th Dec 2019 7:36pm
GGDR
As NMJ says Worth checking the top of that pipe, and also the oil cooler generally top of the 'Vee'.
Oil can definitely work its way down there.
If it is the turbo then your removal list is about right. Sad
You might be able to leave the sub frame. Cheers, Greg
Post #538626 27th Dec 2019 7:52pm
When I say top end I mean at the back top of the engine and running down have a look here as a possible source which is a damn site easier to fix. https://www.fullfatrr.com/forum/topic35977.html?highlight=o+ring There is nothing that can't be fixed with a hammer😜😜
Post #538627 27th Dec 2019 7:55pm
madpugger
Thanks guys, had a quick look at the cooler end but don't see much oil there.
When the engine is running, the oil pours off the LHS turbo at the cold side. We've stuck a camera in there but it's hard to see. its wet around the drain and not much higher, but hard to see why the drain would leak so badly...
Post #538637 27th Dec 2019 8:44pm
Should give you an idea of what feeds go where. There is nothing that can't be fixed with a hammer😜😜
Post #538642 27th Dec 2019 9:01pm
66jag
Having the same problem with mine, oil leak from area of n/s turbo, did you ever get to the bottom of the problem? The issue as you say is seeing where the oil is coming from, local garage wants to drop the engine and fit a new turbo but at £3k+ I’m not ready to fire the parts cannon...
Post #567750 22nd Sep 2020 6:09pm
