Home > Technical (L322) > 4.2 SC - Copious amount of steam on start-up
Glibbs
Hi, it stops once the engine is warm. Using about 1-2 pint of coolant per week. No sign of any cross contaminant.
Any help gratefully received before I head for another huge bill please. Range Rover 4.2 SC
2 Range Rover Classics - one from new but both rusty now.
Rover 3.5 Coupe had since new.
Subaru Legacy 3.0.
BMW K1200RS.
Post #539574 6th Jan 2020 9:14am
V8Noise
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
Get a sniffer test done. Cheap and easy at your local garage. It'll point to exhaust gases in the coolant, ergo, possible head gasket problems. 2017 5.0 Autobiography Supercharged
2005 Merc SL350
2005 Disco HSE 2.7 oil burner
Post #539578 6th Jan 2020 10:26am
Mulcher
England 2006 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
Where is the steam coming from? 2006MY 4.2 SC
BMW R1250 GSA Rallye TE
Triumph Tiger 1050 (sold)
1979 Pontiac Trans Am (sold)
Post #539715 7th Jan 2020 1:59pm
Glibbs
From the exhaust. Range Rover 4.2 SC
Subaru Legacy 3.0.
BMW K1200RS.
Post #539727 7th Jan 2020 3:11pm
Sandyt
It might be worth taking the plugs out and having a look to see if any are steam cleaned or rusty
Post #539758 7th Jan 2020 7:47pm
If you are loosing coolant and steam is coming out of the exhaust on start up it's likely you have a head gasket problem.
Coolant is being sucked into the cylinders during the induction part of the cycle and expelled through the exhaust.
The steam out of the exhaust appears to disappear after a while due to the increased temperature as the engine warms which means the steam doesn't condense. Takes me back to my yoof when I had a mini that did exactly the same. Fitting a new head gasket cured the problem.
Post #539759 7th Jan 2020 8:15pm
MattHughes86
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
We had similar problem at first, which then led to an over heat problem.
head gaskets is where i am at now..
this is what you will end up looking at.
im also re-setting all my valve clearences while im at it, this part is taking the longest getting the damn tappets sorted.
Matt If In Doubt Give It A Clout
Previous Vehicles:
Land Rover 110 3.5 V8 (is my dads though)
1.9TD Seat Toledo
1.4 Rover 214 (dont ask)
2.0 Nissan Primera SLX (i want it back)
1.4 Seat Ibiza
996cc Toyota Aygo (I miss this car???)
04 TD5 Discovery 2 (my Current Car)
07 4.2 SC FF (wifes car)
Post #539830 8th Jan 2020 1:39pm
Glibbs
Many thanks. Range Rover 4.2 SC
Subaru Legacy 3.0.
BMW K1200RS.
Post #539831 8th Jan 2020 2:38pm
kezbo1981
United Kingdom 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
@matthughes86 what's access like for what you are doing? I've always thought if I have to go that deep I would take the whole engine out.
Post #540021 10th Jan 2020 9:43am
MattHughes86
Kezbo,
i have took the whole rad system out inc air con rad,
due to that access isnt so bad, there are a couple of annoying things to work round and twist a wrist or two like the alternator and the air con pump, but ok to work round.
some of the stuff at the back is a pain but i found just standing/sitting on the block sorted that out...
i just want my tappets so i can start the rebuild properly starting to forget where bits went.....
incase you wondered out of the 32 tappets im having to change around 26-28 of them
Previous Vehicles:
1.9TD Seat Toledo
1.4 Seat Ibiza
Post #540024 10th Jan 2020 10:07am
