![]() | Home > Maintenance & Mods (L322) > P023D “fix” |
gilesharrison Member Since: 04 Aug 2018 Location: Cumbria Posts: 163 ![]() ![]() ![]() |
Sorry, what is 'bodying'? |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 780 ![]() ![]() |
That's what auto correct thinks bodging should be |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2947 ![]() ![]() ![]() |
Is this a good idea though? If there is a boost fault for example and the car doesn’t go into protected mode, it will likely cause damage? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
You could be right which is why I'm not recommending this just floating the idea as an option that some might want to look at.
Who did the gap file and what was the cost?
It was Pete Bell at BAS, I had to send him the Map from mine for him to look at first before he could give me a price so I don't want to tie his hands if yours is a more complicated job, suffice to say it was the cheapest of all the repairs that I've tried so far. I did everthing by Email and his comms and service were first rate. |
I have spoken to Pete in the past regarding my fault. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
If anyone is considering this "fix", I've now done 1500 miles with no problems or fault codes so while I would never suggest this as an alternative to looking for the real cause of the problem I think it is a good way of getting some more life out of a car whose value wont justify a big spend on repairs. |
I’m just about to do something that I haven’t tried before and if it works I’ll be very annoyed with myself. I’m changing both MAP sensors for new ones.
