![]() | Home > Technical (L322) > Is this normal? - EGR Temp? |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3879 ![]() ![]() ![]() |
Does this help ?
M@r]{ Member Since: 03 Nov 2019 Location: Northants Posts: 165 ![]() ![]() ![]() |
Yes thank you. Just confirms I have yet another problem I need to deal with. My first toe dip into the water of RR ownership is going to be a short lived one at this rate.
Caution !,
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3267 ![]() ![]() ![]() |
IIRC the bank 2 sensor is only for the second turbo and so only goes up on the very few occasions that the revs get over 2500 |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4348 ![]() ![]() ![]() |
Boot it above 2500rpm and it should climb up in value |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 342 ![]() ![]() |
An IIDTool will tell you if the sensor is broken but as Dr Rob infers the Bank 2, Sensor 1 is the sensor on the second turbo which only spins up when you boot the throttle. Usually it sits at 100°c as the default reading.
