Home > Maintenance & Mods (L322) > Paddleshift/Command-shift Mod for 2002-2010 cars
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
Does anyone have an interest in a Paddleshift/Command-shift modification for 2002-2010 cars?
I've just sold my car that has been used to develop a retro-fit kit to allow the earlier cars to have the same Paddleshift/Command-shift feature as the modern cars.
The kit takes about an hour to fit. It is completely plug-n-play and requires no cutting of wires etc. Everything continues to work as it should - even the heated steering wheel. No fault codes are registered and the car behaves exactly as if it came from the factory with Paddleshift.
The Paddleshift kit has 2 modes:
1. Pull on one of the paddles and the car immediately switches into command shift mode. You can change down or up as you wish. After about 10-15 seconds of not pulling a paddle, the car reverts to Auto mode.
2. Push the gear lever into Steptronic mode, and the car can be driven manually using the Paddleshift system.
Philip1972 bought my car last weekend and has reviewed the modification here: www.fullfatrr.com/forum/topic54579.html
We're having 25 kits made at the moment, which should be ready in the next few weeks. Once they have arrived, we'll make them available on the For Sale section. The kits will come complete with 2 genuine LR paddles, and 2 modules that plug in to the existing steering wheel and gear-lever wiring. The aim is that the kits should be less than £200.
Please send a PM if you are interested in one of these first kits. Current:
- 2017 L405 3.0 V6 Autobiography
Sold:
- 2013 L405 4.4 TDV8 Vogue
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #544131 16th Feb 2020 6:36pm
be careful not to breach the forums 'for sale ' rules Wink
in fact i think a message to the site owner Martin to make dure its ok would be advisable.. ... - .- -.
Post #544135 16th Feb 2020 7:09pm
Zebedee
Have sent Martin a message.
Thanks Stan. Current:
Sold:
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
Post #544139 16th Feb 2020 8:44pm
