Home > Technical (L322) > Battery compatability |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
That one you mention is an 017 however I believe you need an 019
27th Feb 2020 11:31pm |
Interestingly the 017 you mention is
27th Feb 2020 11:36pm |
Leesbay Member Since: 05 Dec 2019 Location: Rainford Posts: 53 |
Yes that fact confuses me too
27th Feb 2020 11:39pm |
Gazcw Member Since: 11 Jan 2020 Location: Northampton Posts: 172 |
Exide is the go to battery for Maserati owners. They are VERY sensitive to low voltage and most owners have them on trickle chargers. I will be buying one of these once you have the 017/019 answer as my LR battery is failing. 2011 4.4tdv8 Vogue
27th Feb 2020 11:50pm |
Will post back with answer asap
27th Feb 2020 11:54pm |
jordon0 Member Since: 06 Mar 2016 Location: derbys Posts: 52 |
run an ek950 on my tdv8
28th Feb 2020 9:07am |
Tanya confirm its a match
28th Feb 2020 11:46am |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1097 |
My experience, and there is a thread somewhere -- specifically for 4.4 TDV8 is it needs to be - 019 (not 020) and AGM -- get those two things and it's then simply a choice of manufacturer, which I accept is a different kettle of fish Current: 2011 FFRR Vogue SE 4.4 TDV8
28th Feb 2020 11:58am |
Strange. That code does not work and total cost is 134.78 2011 4.4tdv8 Vogue Baltic Blue |
28th Feb 2020 12:14pm |
Ah it is via ebay and not their website.Do you buy it now and add the code via paypal? 2011 4.4tdv8 Vogue
28th Feb 2020 12:19pm |
Bluegreygreen Rangie 2 Member Since: 27 Feb 2020 Location: Australia Posts: 74 |
Guys if you want to fit a real battery to your car forget all of the above, Fit either and only a Northstar or Odyssey (both companies have one model which fits and exceeds all other options.. Ive done all the research for you beleive me
28th Feb 2020 4:00pm |
Odyssey equivilent below
28th Feb 2020 4:05pm |
Gazcw
28th Feb 2020 5:32pm |
Im sure the Odyssey is a cracking battery but for us UK owners it appears that the battery posts are different and the fact we need to ‘fettle’ would certainly invalidate any warranty
28th Feb 2020 5:37pm |
