![]() | Home > Maintenance & Mods (L322) > Rear towing socket electrics |
Jon G Member Since: 02 Dec 2016 Location: Leicester Posts: 120 ![]() ![]() ![]() |
When i got my Car i swapped the 2 7 Pin Sockets for a 13 Pin one to suit the Caravan.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4348 ![]() ![]() ![]() |
A 13 pin genuine LR lead is easy to fit and is plug and play on your model year. The only tricky bit is fitting the rubber grommet through the body (use silicone spray as a lubricant).
Mousey Member Since: 22 Mar 2020 Location: Leicestershire Posts: 20 ![]() ![]() ![]() |
Thanks to you both for suggestions but as I need it urgently it's gone into dealer this evening for work thursday, Fingers and credit card crossed.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8775 ![]() ![]() ![]() |
As above, easy and cheapest fix is to swap the plug. They shouldn’t charge you an arm and a leg as it’s a quick plug and play! There is nothing that can't be fixed with a hammer😜😜
Let us know what they charge you for it. A new 13pin genuine loom was around the £80 mark I think....Time to fit = <1hour. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
All done and dusted, dry joints in back of socket, Happy Bunny!! |
