Home > Technical (L322) > USA 2007 Supercharged won’t start. No crank. Immobilized ? |
Laurie915 Member Since: 11 Sep 2011 Location: Canberra Posts: 72 |
07 Models in UK did have a run of bad ignition switches, all describing similar problems. Not a big job if your handy !
23rd Mar 2020 10:12pm |
DucatiBrandon Member Since: 22 Feb 2020 Location: Arizona Posts: 19 |
Thank you. I’ll swap it |
24th Mar 2020 1:07am |
No luck. Anyone have an idea before the stealership gets it? |
28th Mar 2020 1:41am |
Brandon
28th Mar 2020 2:30am |
That’s a different issue but the button sequence is the same. Mine just won’t crank over. My locksmith came back out and took the small computer (immobilizer) with him and did some testing in his office. He said he found 4 keys programmed and was also going to try and do some computer reset on Sunday. I figured he could try before she gets sent off to the dealer.
28th Mar 2020 3:16am |
For those of you who care we found the issues.
1st Apr 2020 2:59am |
That's good news Brandon ! Water ingress is a problem with some cars, it really is a hit or miss with the car you buy. Enjoy the wonderful engine
10th Apr 2020 2:24am |
Thank you for the response as I love this thing. Unfortunately She died on the highway a couple days later. Won’t start but she cranks and Cranks and cranks. I put a new fuel pump and kit in but still no luck. She has a lot of fuel pressure. I metered the coils and wire 2 is holding at 4.78 vdc and not pulsing. I wonder if the regulator in the fuel rail is bad. Any ideas |
10th Apr 2020 4:11am |
Crank angle sensor ?
10th Apr 2020 6:22am |
tb10 Member Since: 17 Feb 2015 Location: Bromsgrove Posts: 332 |
Two thoughts:
10th Apr 2020 9:05am |
