Home > Maintenance & Mods (L322) > Air con pulley or tensioner
Vogue Owner
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Java Black
Had my air con re-gassed today and was told that the pulley belt isn't turning the air con pump but the belt is still in place?
Anyone had this ?
If it's the tensioner pulley is it a big Job? Is it a DIY job? CURRENT : FFRR 2012 4.4 TDV8
GONE : Discovery 4
GONE : BMW M5
GONE : L322 Range Rover
GONE : 2007 MITSUBISHI OUTLANDER
GONE : SAAB 9-3 VECTOR SPORT
GONE : BMW M3
GONE : SIERRA COSWORTH
GONE : LOTUS CORTINA
GONE : MK1 MEXICO
GONE : MK2 RS2000
Post #58940 5th Apr 2011 7:33pm
nbunney
United Kingdom 2018 Range Rover Autobiography SDV8 Corris Grey
When I got my TD6 the pulley had siezed. I could not get it out so it went to my mechanic and in the end he took the compressor off Rolling Eyes
Post #58969 5th Apr 2011 9:03pm
Easy job. DIY! They use a sprung loaded shock the thing to keep constant pressure and tension in the belt.
Post #58983 5th Apr 2011 9:59pm
Check the tensioner (number 2 below) is working properly as they are a common fault
Post #58985 5th Apr 2011 10:09pm
nbunney
Thats the 1 that had siezed on mine Thumbs Up
Post #58988 5th Apr 2011 10:20pm
Vogue Owner
if the tensioner is seized then the belt wont be turning right?
And as for a DIY job - ive had a look and it would seem a whole lot of components - rad e.t.c. need to come out - or can it be done from beneath? CURRENT : FFRR 2012 4.4 TDV8
GONE : Discovery 4
GONE : BMW M5
GONE : BMW M3
GONE : MK1 MEXICO
GONE : MK2 RS2000
Post #59062 6th Apr 2011 4:15pm
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
You can access from underneath by removing the front guard first.
Post #59065 6th Apr 2011 4:23pm
What Richcl said. I took the fan and cowel off as well just to have extra room and to allow the belt to go on easy without feeding it over the fan.
Post #59078 6th Apr 2011 4:43pm
Is this the thing that is supposed to go click when you turn on the A/C?
I regassed last year (500kg ! for those who remember Smile) and have been running with the A/C across the winter for Dan Smile
However, with this warm spell, not getting any cooling.
Listened in on the engine bay, with son pressing the A/C switch and no click, so sounds like I'll have to dive underneath and have a tinker.
Had the same problem when I bought the car 3 years ago.... .
Post #59743 11th Apr 2011 12:55am
You must have a leak in the system Joe90, most probable culprit is the condenser
Post #59761 11th Apr 2011 9:53am
Not been using the FFRR due to good weather, but took the opportunity today to dive underneath and see what was going on.
1. Belt tensioner in "on" position all the time, whether aircon switched on or off, is that right?
2. Can move the belt tensioner so its not seized (using an extension bar)
3. Still not hearing a click when the aircon is switched on (entertained my daughter who was sat in the drivers seat, whilst I was waving a feather duster to indicate my need for the aircon to be swtiched on or off Smile)
4. Stuck a screwdriver into one of the aircon nipples, a small "pfff", then nothing, so I guess I have no gas, hence no cooling!
5. Off to KwikFit or I'll get a mobile chappie round at work next week .
Post #61326 23rd Apr 2011 3:25pm
dont know about 1 and 2 joe,
number 3 , priceless memory
number 4, to the left of the rad is a tube with a valve , take the rubber cap off and press the valve insert, if nothing comes out then there is no gas in the system..re-charge and it should be ok..i did all this and mine seems to be ok now.. ... - .- -.
Post #61327 23rd Apr 2011 3:30pm
dan_uk_1984
@ Joe90:
The click you can hear (or cant) is the A/C clutch locking or unlocking. This is on the face of the A/C Pump itself.
As you say, drop it down to KwikFit and get them to do their re-fill as they dont charge if it doesnt work. Or a mobile guy might actually know what he's doing and find your leak for you...
If you do get KwikFit to do it, ask them "Will your machine detect a leak?" then when they say "yes" you can then get your money back if all the gas leaks out next week.
Dan
Post #61337 23rd Apr 2011 5:47pm
ogy
United Kingdom 2003 Range Rover Vogue Td6 Bonatti Grey
I have had a similar problem. mine was as follows. the air con compessor has a magnetic clutch which pulls an outer cover pulley inwards on the compressor to drive the inside shaft of it. when looking at the comp pulley you should see a central bolt head. a common problem is this bolt comes loose and the front of the pulley falls off. mine was still sat on the bottom cover and simply bolted back on. if you look at the pulley and can see a threaded hole youve lost the outer clutch pulley.The picture in the earlier post showing the compressor shows a small circle in the centre of pulley this is actually a hexagonal bolt head. I think you will have to buy a new pump if the cover is lost as it is not available seperatly. I would get a cover from a breakers,much easier than changing the comp. Adam.
Post #61349 23rd Apr 2011 10:08pm
Slow worker but finally got air con looked at (after the hot weather in April things cooled off so not needed Smile). Turns out I have a leaking condenser (explains a lot!) so getting a new one, then will get gassed up. .
Post #72183 12th Jul 2011 11:10pm
