![]() | Home > Maintenance & Mods (L322) > White Smoke Cloud L322 4.4. TV8 |
| Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3285
if you are getting limp mode, a recurring DPF amber and red and full DPF, then I would suggest you have an air leak, possible any of the 4 pipes to the plenum on top of the engine, or a cracked inlet manifold (passenger or driver side).
| maxg67 Member Since: 10 Jan 2020 Location: Verbania Posts: 12
Thank you Dolphinboy,
| GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561
Does sound similar to another white smoke report here:
Also welcome!
Just re-reading your issue, an air-system leak it could have caused the smoke, given you found one loose hose this could have been the case. Maybe. I would monitor it.
Thanks GGDR,
| Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1057
The colour of the smoke indicates the type of fault you may have, white smoke is air in the fuel. Hopefully you have found the problem with the loose hose |
