Home > Technical (L322) > Rear seat recliner and backward,forward adjustment not worki
bruce
United Kingdom 2010 Range Rover Autobiography 5.0 SC V8 Stornoway Grey
Newly acquired 5.0 SC rear seat electrics appear to be dead, I have checked the fuses which are OK any other quick fixes? If you are not part of the solution you are part of the problem!!
Post #548572 28th Mar 2020 5:50pm
GGDR
Check your drivers door kid lockout switch
. Cheers, Greg
Post #548574 28th Mar 2020 5:53pm
bruce
Do you mean the rear window lock out switch? If so yes I have tried that. If you are not part of the solution you are part of the problem!!
Post #548578 28th Mar 2020 6:05pm
Have you been trying them with the ignition on or off? As they time out after a specific time period... Thumbs Up
Post #548580 28th Mar 2020 6:18pm
bruce
Engine running. If you are not part of the solution you are part of the problem!!
Post #548581 28th Mar 2020 6:26pm
GGDR
Yes.
Failing that and wot Craig said if you are confident about fuses then a bit of detective work I guess.
Can the passengers seat be controlled from its own switches? (Fore/aft)
Do both rear controls not work or just one?
Do the heat/cool dials light up and work the climate seats?
Can the rear windows be operated from their own rear controls?
. Cheers, Greg
Post #548582 28th Mar 2020 6:26pm
bruce
Front passenger seat is ok, rear windows work from the switches in the rear, heating and cooling switches illuminated. The two fuses are both 20 amp and are both good. If you are not part of the solution you are part of the problem!!
Post #548584 28th Mar 2020 6:36pm
GGDR
Rear heating and cooling actually works though?
Also regarding the driver's lockout, just test it does lock out the windows.
If this does not lock out the rear windows then that drivers switch pack could be faulty.
If it were me I'd start with a battery reset.
If you have an IIDTool then check and clear errors.
Then I'd be looking for the connectors under the seats.
Also have a look at the workshop manual in the wiki?
. Cheers, Greg
Post #548589 28th Mar 2020 6:55pm
bruce
I’ll check the lockout switch, I’ve run two scans and found several faults which I have cleared but the seat issue is not coming up. I will also check to see if the heated seats actually heat. I can’t understand why it’s not showing as a fault. If you are not part of the solution you are part of the problem!!
Post #548591 28th Mar 2020 7:08pm
bruce
What’s the wiki? If you are not part of the solution you are part of the problem!!
Post #548599 28th Mar 2020 7:30pm
top right of page.. ... - .- -.
Post #548601 28th Mar 2020 7:40pm
bruce
Sorted the seat issue, went into the CCF deleted all the functions that didn’t work, then went back in and showed them fitted and hey presto they all work.
Thanks to all for comments and advice. If you are not part of the solution you are part of the problem!!
Post #548682 29th Mar 2020 2:24pm
